The second error as the message indicates you have to process AR cube. This was already discussed in this forum. Please search in this forum for how to process cubes.
However i am getting "Default value or value provided for the report parameter ‘Period_Year’ is not a valid value. " and "Default value or value provided for the report parameter ‘TopNCustomers_EndDate’ is not a valid value. " for which i could not find any posts.
From the errors is looks like EP is talking to SSRS and to SSAS. The errors now are just data related within the cubes. Do you have the cube cleanup completed and have the cubes been processed? If not then getting the cubes processed would be your next steps. If you’ve done this already, then it might be due to some of the data. Verify that you have ledger periods defined and you may also need to go through the following steps to update the time dimensions.
Administration > Setup > Business Analysis > OLAP > Timte Periods > Import > Import from AOT
While i am trying to load Report Libraries to VS from AOT, I am getting an error as “Exception from HRESULT: 0x80041FE1” in Visual Studio 2008.
Any clue on how it can be fied?
And also, while i am trying access the quiry from Report Builder (Internet Explorer >> Open reports site (http:///reports) >> find specific report and Right Click >> Edit in Report Builder >> In Report Builder, Select Data set properties and Click Query Designer) i am getting below error
TITLE: Microsoft SQL Server Report Builder
An error occurred while connecting to the data source. Only the text-based query designer will be available.
ADDITIONAL INFORMATION:
The selected data extension AXDATAMETHOD is not installed or cannot be loaded. Verify that the selected data extension is installed on the client for local reports and on the report server for published reports. (Microsoft.ReportingServices.Designer.Controls)
Any clue how it can be fixed?
FYI: Our environment is Win2008 Sever R2; SQL 2008 R2; All AX components installed in single server
