How to consume the rest api in ax 2012.
I have tried the below code but i getting error like “Authorization 301 error” in response line.
How to resolve the error
static void ODataservice(Args _args)
System.Net.HttpWebRequest request;
System.Net.HttpWebResponse response;
CLRObject clrObj;
System.Byte[] bytes;
System.Text.Encoding utf8;
System.IO.Stream requestStream, responseStream;
System.IO.StreamReader streamReader;
System.Exception ex;
System.Net.WebHeaderCollection httpHeader;
str byteStr;
System.Byte[] byteArray;
System.IO.Stream stream;
System.IO.Stream dataStream;
byteStr = strfmt('%1:%2', "USERNAME", "PASSWORD");
try
new InteropPermission(InteropKind::ClrInterop).assert();
httpHeader = new System.Net.WebHeaderCollection();
clrObj = System.Net.WebRequest::Create(url);
request = clrObj;
utf8 = System.Text.Encoding::get_UTF8();
request.set_KeepAlive(true);
request.set_ContentType("application/xml");
byteArray = utf8.GetBytes(byteStr);
byteStr = System.Convert::ToBase64String(byteArray);
httpHeader.Add("Authorization", 'Basic ' + byteStr);
request.set_ContentType("text/xml; encoding='utf-8'");
request.set_Method("POST");
request.set_Headers(httpHeader);
requestStream = request.GetRequestStream();
response = request.GetResponse();
responseStream = response.GetResponseStream();
streamReader = new System.IO.StreamReader(responseStream);
responseXml = streamReader.ReadToEnd();
info(responseXml);
catch (Exception::CLRError)
//bp deviation documented
ex = CLRInterop::getLastException().GetBaseException();
error(ex.get_Message());
requestStream.Close();
streamReader.Close();
responseStream.Close();
response.Close();
