Error in report
When I am trying to print cheque in Ax 2012, system is throwing the following error
‘Access denied to method validateDataContracts in class sysOperationFrameworkService.’
Any suggestions ?
Thanks in advance.
Faisal Raja J
Hi Faisal,
I think you have not assigned the server method to the corresponding security privilege… For your reference pls go through the below link which may help you
http://www.k3technical.com/dynamics-ax-security-and-the-business-operation-framework/
Abbas
Hi Faisal,
Did you find solution of this problem? I am facing same issue.
Irum
