hi i’m encountering this error:
Invoice rounding Precision must not be 0 in Currency Code=".
i’m pressing F9 from Order button…
can you help pls…
thnks
can you help pls…
thnks
Financial Management - Setup - General Ledger Setup
General Tab - Set the Invoice Rounding precision to anything except 0.00
You have two options:
I was making the leap of faith that as invoice rounding was required it needed to be setup, but as Girish correctly points out, you can ignore invoice rounding completely to resolve the issue as well - depends what you want to do with your invoice rounding!
