Error in Processing Cubes !!!
Hi friends,
i am trying to process the cube so that it could be seen on Role center in AX 2009 Home module.
When i open SQL Business Intelligence Development Studio (BIDS), i processed the dimensions & after that when i tried to process the cube i got error and notifications.
The very 1st notification that i got was
The server Content appears to be out of date"
i continued…
The 2nd notification was
The ‘AX_BI’ database on ‘localhost’ has changed since the last time the project was deployed. If you proceed with deployment, the database will be overwritten.
Would you like to continue?
i continued…
And after that i got the errors in processing
Please help me to get it done…ASAP :confused:
Thanks in Advance
