Dear All,
I am using Nav 2009. My problem is when i am working with NAV some times an error happends and ask me to restart. The error message is " You can not use the file C:/Users/appli.data/temp/_temp_678393.tmp because its already in use " …
I tried a lot to solve the issue but i can’t !!! Any body can help me to solve this issue ??? Thanks in advance
Ragards
Abhilash
this is because you are probably using KAV or KIS 2010.
disable them (or any antivirus/internet security software) you have and it should work.
for sure this is a TEMP solution until some fix patch or something is released for this issue.
and if any one here knows another solution for this please post it.
thanks.
Thak You very much , your advise is helps me verymuch .[:D]
there is more “Realistic” solution .
from the settings of KAV or KIS exclude NAV from being monitored (Application Activity, child activation activity)
for sure this is way better than disable the antivirus
