Error in inserting data in table
i have created a table in which data get inserted when the user insert a value in decimal field,
For one document it is inserting the data but for second document it is showing error,
My code,
IF “Freight Amount” <> 0 THEN BEGIN
RecFrtLog.RESET;
RecFrtLog.INIT;
RecFrtLog.“Serial No”:=RecFrtLog.“Serial No”+1;
RecFrtLog.“Document No.”:=“No.”;
RecFrtLog.“Port of Discharge”:=“Port of Discharge”;
RecFrtLog.“Freight Amount”:=“Freight Amount”;
RecFrtLog.“User ID”:=USERID;
RecFrtLog.“Date and Time”:=CURRENTDATETIME;
RecFrtLog.INSERT;
END;
i have written this code in On Insert of sales header.
In your line: RecFrtLog.“Serial No”:=RecFrtLog.“Serial No”+1;
It will allways be 1 in your code.
In you use RecFrtLog as a Entry No. You need to go look in freight rate log entries.
You could do a findlast
Use
IF RecFrtLog.findlast THEN
ELSE
RecFrtLog.“Serial No” :=1;
And you could change the line:
to
RecFrtLog.“Serial No” +=1
Dear All,
my data is not inserting in table
var
LastRecFrtLogNo: integer;
RecFrtLog.RESET;
IF RecFrtLog.FINDLAST THEN
LastRecFrtLogNo := RecFrtLog.“Serial No” + 1
ELSE
LastRecFrtLogNo := 1;
RecFrtLog.INIT;
RecFrtLog.“Serial No”:=LastRecFrtLogNo;
RecFrtLog.INSERT;
END;
