Error in importing the Excel file to insert in the Table
I want to import the Excel File to insert in the table in AOT .I use the Job to Import the Excel File. But when i use the JOb Is Shows Error…
Hello Cristiano,
can you check if your path and file name are correct,
with or without space in name and also try to paste this path of file into run and try to open.
Can you check if you have access to this path ?
You can test this file from other path.
