I am trying the Technical Article of (Talking with Navision in MSDN). But I got these problem in event viewer:
The description for Event ID ( 20010 ) in Source ( MICHAEL-SQL ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: The previous 20 reported events were identical.
In order not to overcrowd the message logging system, identical events will not be logged until after the program reports a different event.
Is this problem have anything to do with the setup of my Application Server or I need to configure something before I start the Application Server?
I’m using NAVCOMM to start it. It’s not a new piece of code. It’s same as the technical article. By the way, it’s already started. But it still showing the warning message. The problem was cause by NAVCOMM codeunit. I didn’t define full path of the Message Queue.
The problem now, what I send from .net, I didn’t get the message back from NAV. I checked the queue, and I found out the queue from .net is created. But I didn’t get any message from NAV. Is there any way that I can figure out whether:
Message reach NAV or not. or
Message reach NAV, but NAV can’t send it back. or
Message are send from NAV but .net didn’t catch it.
You must understand the code and the function that you are installing to debug.
Try step-by-step development: develop, implement and test in simple steps from first level (for example starting the NAS and running one Codeunit to execute one function) leading up to full function. Then you can see what is working and what is not working.
