Error in Dimension Statement Report
i am unable to open the Dimension Statement Report.
It is Throwing the Error.
Below error
TempDB table field cannot be empty for RecId 5637191865.
(S)\Classes\xInfo\add
(S)\Classes\Info\add - line 94
(S)\Classes\Global\error - line 3
(S)\Classes\SrsReportProviderQueryBuilder\initializePreProcessedDetails - line 36
(S)\Classes\SrsReportProviderQueryBuilder\initialize - line 26
(S)\Jobs\
Have you found the solution? I got the same error on many reports.
TempDB table field cannot be empty for RecId 5637148326.
(S)\Classes\Info\add - line 101
(S)\Jobs\
You guys should ask technical to do full compilation application, run full cil…Then the error will gone. Cus this error is due to application issue. Hope it helps
