Hi All
I am trying to create a user workflow and i get the error as below
0882.New Bitmap Image.bmp (1.39 MB)
And checked the logs, the error is “Workflow threw an exception for the following reason: Unable to log on to Microsoft Dynamics AX.”
And i am using the Admin login which has all the Rights
7635.work 1.bmp (1.3 MB)
Please could any one help me out
Thanks a lot in advance
Re-install the .Net business connector. It will work for sure
Thanks a lot for the reply
Could you also please help me know how to install .Net business connector and a link for exe file
Thanks a lot for reply
Could you also please help me out in how to install .Net business connector and the link for exe file
You need to use the same exe file which you had used while installing AX. Just enable the .Net business connector component and continue with the wizard. Check this out: http://technet.microsoft.com/en-us/library/aa548683.aspx
Also have you configured workflow execution account properly. Just check once in System administration=> Setup=> System=> System service accounts, set Workflow execution account to Admin or the alias for workflow execution.
