Error handling in navision
How to handle automation control error in Navision ? same like Try catch in .net
I have resolved the Automation error handling problem.
Let’s I have explain
Step 1
Create two code unit
Codeunit A
Codeunit B
Step 2
In Codeunit - B
Declare the global variable
Add1
City
Region
Postcode
Country
Create Two function in codeunit B
  1. SetParameter(_Add1,_City,_Region,_PostCode,_Country)
    Add1 := _Add1;
    City := _City;
    Region := _Region;
    Postcode :=_Postcode;
    Country := _Country;
2)IsAddressFind()
//Map Point Automation Variable
MapPointFindResult := MapPointMap.FindAddressResults(Add1,City,‘’,Region,PostCode,Country);
OnRun() - Trigger
IsAddressFind()
Step 3
In Codeunit - A
Decalre Bool varible Isyes
Declare B as Codeunit B
Initi Map
Create Function
GetLocation(_Add1,_City,_Region,_PostCode,_Country)
CLEARLASTERROR();
// Pass the parameter in codeunit b becuase we can not pass the parameter in run so i have create setparameter function and passs it
B.SetParameter(_Add1,_City,_Region,_PostCode,_Country)
IsYes := B.Run();
IF IsYes = FALSE THEN BEGIN
message(GETLASTERRORTEXT);
CLEARLASTERROR();
end else begin
message(‘Sucessfully executed’);
END;
Close Map
Please note - I am not write 100% accurate code , I have just try to explain how to handle error
I hope this solution help to our community for handling error in navision
