Error executing code: Wrong type in field number.
I get error when deploying the form.
Error is in CatalogRequest form.
error detail:
(C)\Forms\jsCatalogRequest\Methods\init - line 24
(C)\Classes\SysSetupFormRun\init - line 3
and the code is
[code]
06/29/2005
<TRACKING_ID>F424, D907</TRACKING_ID>
Loads active catalogs for customer.
Set buttons for quick key access.
[/code]
public void init()
CustAccount custAcct;
smmBusRelAccount busRelAcct;
smmBusRelTable tBusRelTable;
jsTmpCustSearchTable tTmpCustSearchTable;
// D4056 - Removed call to element.jsSetQuickKeys();
super();
switch(element.args().record().TableId)
case(TableNum(CustTable)):
custAcct = CustTable::findRecId(element.args().record().RecId).AccountNum;
break;
case(TableNum(SalesTable)):
custAcct = SalesTable::findRecId(element.args().record().RecId).CustAccount;
break;
// F1391 5/23/07 - support sending a catalog to a BR
case(TableNum(smmBusRelTable)):
tBusRelTable = element.args().record();
custAcct = tBusRelTable.CustAccount();
busRelAcct = tBusRelTable.BusRelAccount;
break;
// F7333 10/25/07 - support sending a catalog from customer search
case(TableNum(jsTmpCustSearchTable)):
tTmpCustSearchTable = element.args().record();
custAcct = tTmpCustSearchTable.CustAccount;
busRelAcct = tTmpCustSearchTable.BusRelAccount;
break;
jstmpCatalogRequest.initFromjsCatalogSetup(custAcct, busRelAcct);
jstmpCatalogRequest_ds.executeQuery();
Please anybody reply me regarding this error.
Thanks to all.
Hello,
Your error is coming on the code line:
It is so because your form is not called by any other form. Because of this the value of element.args().record() is null and hence a null record should not have a TableId. So an error is thrown:
To prevent this error just include an if condition in the init method as shown below:
if (element.args().record())
break;
