Error executing code: Wrong argument types in variable assignment.
Good day guys,
I have implemented a new button on PurchLineBackOrderListPage which resets all BackOrder Quantity to zero from selected lines. I used a Dialog class to get the selected records from the form using the following code:
private void UpdateBO(Args _args)
Counter i;
Dialog dialog;
DialogText dialogTxt;
DialogButton dialogBtn;
FormRun caller;
FormDataSource formDS;
MultiSelectionHelper helper;
PurchLine purchLine;
dialog = new Dialog();
caller = _args.caller();
helper = MultiSelectionHelper::createFromCaller(caller);
dialogTxt = dialog.addText(‘Deseja atualizar as quantidades pendentes das linha selecionadas?’);
if (dialog.run())
for (i = 1; i <= caller.dataSourceCount(); i++)
formDS = caller.dataSource(i);
formDS.name();
if (formDS.name() == ‘PurchLine’)
break;
helper.createQueryRanges(formDS.queryBuildDataSource(), fieldStr(purchLine, RecId));
purchLine = helper.getFirst();
while (purchLine)
info(strFmt(’%1’, purchLine.RecId));
purchLine = helper.getNext();
But then I get the following error:
I understand that this error happens on “purchLine = helper.getNext()” but I really don´t understand why. Help please.
If my description is not understandable please tell me.
