Docuref Table → Delete method
void delete(recId _interCompanyFromRecId = 0)
DocuValue docuValue;
Filename completeFilename, onlyFilename;
NumberSequenceCode numSeqCode;
DocuType docuType;
ttsbegin;
smmTransLog::initTrans(this, smmLogAction::delete);
super();
InterCompanyDocu::synchronize(this,_interCompanyFromRecId);
if (!this.existAnotherValue())
docuValue = DocuValue::find(this.ValueRecId, true);
if (docuValue.RecId)
completeFilename = this.completeFilename(this.path(true));
onlyFilename = docuValue.FileName;
docuValue.delete();
docuType = this.docuType();
if( completeFilename )
if (docuType.FilePlace == DocuFilePlace::Archive ||
docuType.FilePlace == DocuFilePlace::NoCopy)
//Check if we need to remove the physical file along with the database record
switch (docuType.RemoveOption)
case DocuRemoveOption::DocumentOnly:
//Keep the file
break;
case DocuRemoveOption::DocumentAndFile:
if (docuType.FileRemovalConfirmation == NoYes::No)
DocuOpenFile::removeFile(completeFilename);
else
switch (box::yesNoCancel(strfmt("@", completeFilename), DialogButton::Yes, “@”) )
case DialogButton::Yes:
break;
case DialogButton::No:
break;
case DialogButton::Cancel: // THE PROBLEM IS OCCUR IN THİS CASE
//Throw an error to cancel transaction with delete operation
throw error("@");
break;
if (smmDocuments::mustArchiveFiles(docuType))
numSeqCode = DocuParameters::numRefDocuNumber().NumberSequence;
if (numSeqCode && onlyFilename)
// Delete the value in the numberseq list
NumberSeq::release(numSeqCode,onlyFilename);
else
ttscommit;
