The quickest way, open your Object Designer, select All. See there is a column ‘Compiled’ and the content should be [Checked]. Find all lines that are not checked in column ‘Compiled’.
You can also filter all lines that are not checked in column ‘Compiled’. Do the compiling by clicking the line, then go to Tools - Compile. or F11.
