error during intercompany set up of chart of accounts
I encountered this error while mapping the chart of accounts in intercompany set up.
Financial Mgt > Setup > Intercompany postings > Chart of Accounts > Functions button > copy from chart of accounts then this error appeared.
"the value of UPDATEINDENT parameter 1 is outside of the permitted range.
the current value is: -220. the permitted range is: from 0 to 2147483647"
Hope you could assist me on how to fix it. I’m a beginner and dont have idea why this error pop up.
thanks in advance
I’ve had the same problem before, How I got rid of the error message was go to the Dimension Value table, there is a field called [Indentation] if there is any value less than 0, for example the old issue of mine was -1, that would throw the error message.
thanks for your time in dropping by. I will try to look into this on Monday at my workstation. i’ll keep you posted. God bless
Hi thanks for giving me an idea. what i did was to update the table in the IC Chart of Accounts using Microsoft SQL. Here’s the command I did, hope this would also help others when they encountered same error.
update “title” set Indentation = 0 where Indentation = -1
