Error dimension code mandatory for system generated entries.
When i am trying to post a transfer order (Receive) getting error,
Select a dimension value for the dimension code BRANCH.
When debugged issue found was that it is posting Unrealized Gain/Loss in Inv. Transfer which is a system generated entry.
I had set up account type default code mandatory for table id 15 (G/L Account) for dimension branch.
What might be the issue, is it related to setup or its an bug.
When i posted transfer order as ship there was no error.
Using NAV 2013 R2 IN Build 36310
Manish,
Not a bug as such more reflecting your current configuration. 2 choices - remove code mandatory on unrealised exchange gains / losses GL code or set the branch dimension to a same code rather than code mandatory (or even populate code manatory with a branch value).
Hope this helps.
Neil
neil@fpconsult.co.uk
I had not set branch code mandatory for any specific account.
I had set this setup in dimension → account type default → table id 15 and code mandatory.
