I got an error ? like this.
Argument “Helpurl” is incompatible with the required type.
Operand Type are not compatible wit the variable name…
this errors appears while creating a date.any other ways of using that…and I need to perform a date…12/12/2013 this is example…
this much be executed in Switch case …Thanks in advance.
which variable type you have created it
its operant type might be mis matching it it to the field you referred .
You can use mkdate function for creating a date.
I can get all this from your post that you are trying to create a date for some operation.
My guess it that you incorrectly use the second parameter of info() or error() method. Nevertheless… show us your code!
