error at read in rule 141, fragment3 06/13/13 for field 4 posting date field type of date proplem
Hi guys i have problem when i make import to data to dynamic nav 2009 it give this error
this error give to me when we import the data by data wizard program
why this error happened and how i solve this problem
Check if its related to Date format in the file you are importing.
Your error tells date as 06/13/13 & your work date shows 25-09-13.
thanks for reply
from database i export date in formate month-day-year
to database i import date in formate day-month-year
how i solve the proplem or how to make date in two database in same formate
thanks
You need to make sure that the field holding the data (ValueText) is converted into a string in the proper format before assigning it. You can use copystr for that.
Although the code looks ok. It should never give the error, not even if the format is wrong. If it is wrong, then it should not evaluate and a runtime error never be given. But which version of NAV is this? 2009?
Thanks for reply
how i use copystr function to avoid difference between date format if possible
If you need to converte a string in the formate month-day-year (eg. 09/30/13) to a string in the format day-month-year (30-09-13) you can do this:
NewDateStr := COPYSTR(OldDate,4,2)+'-'´+COPYSTR(OldDate,1,2)+'-'+COPYSTR(OldDate,7,2);
Hi Ahmed,
Did you try out my suggestion? Did it help you?
The members and moderators here on DUG use our spare time and help you for free, all we ask in return is that you spent a few seconds to let us know if we helped you solve your problem.
If any of the suggestions helped you solve your question/problem, then please click the “Verify Solution” on the answer that helped you, so that we can see that your problem is now “resolved”. Otherwise let us know how if there is something else you like to know.
Have a nice day! [:)]
