ERROR:Argument '_number' is incompatible with the required type.
I have the code for Updating Purchase Order Invoice in My Customized Form in write Method to update the posting into Invoice from That Customized Form .
PurchFormLetter_Invoice invoice;
// Purchtable purchtable;
//CITPickUpReconcil _CITPickUpReconcil;
super();
purchTable = PurchTable::find(_CITPickUpReconcil.PONumber);
invoice = PurchFormletter::construct(DocumentStatus::Invoice);
invoice.update(purchtable,
SystemDateGet(),
PurchUpdate::All,
AccountOrder::None,
false,
true);
But its throwing error Argument ‘_number’ is incompatible with the required type.
near line :invoice.update()
please help me out…
It’s normal. The PurchFormLetter.update() method expects to receive the following parameters :
(Common _source,
Num _number,
TransDate _transDate = this.transDate(),
PurchUpdate _specQty = PurchUpdate::All,
AccountOrder _accountOrder = AccountOrder::None,
NoYes _proforma = this.proforma(),
NoYes _printFormLetter = this.printFormLetter(),
NoYes _usePrintManagement =
false,
NoYes _creditRemaining = this.creditRemaining(),
container _packedTmpFrmVirtualList = conNull())
Regards
Hello pawan,
In the invoice.update() method - you are missing one parameter, that is reason it is showing up that error.
static void Job1(Args _args)
PurchTable purchTable;
purchTable = PurchTable::find(‘000447’);
invoice.update(purchtable,‘15,<need to pass the invoice number - this is missing in the code>
SystemDateGet(),
PurchUpdate::All,
AccountOrder::None,
false,
true);
Thanks Buddy…
Thankuuu…
