Can any one pls provide me any solution for my report design Error
“A section in the report is higher than the actual page size allows”
my Report height is 12 inch on pre printed format where i want to print address string abt 11 inch but it is giving error when i m going to take report. if i remove this string from report then its ok.
Well, When this error come, Follow Steps: (Only Work around)
Clear Local Usaage data, Microsoft Dynamics AX>Tools>Options>Right side>Click Usage Data>press reset.
2)Quit AX 2009
3)Clear/Delete ax_{5EABDA5F-D327-4CD8-AA9B-EE99A8000045}.auc file from location (Window 7 and above) Like this C:\Users\umeshpa\AppData\Local (Command %userprofile%)
4)Open AX 2009 then go to your report>print while printing Select Printer properties and set page to A3, then u can see the reports on screen.
