Error 401 unauthorised when trying to connect to Dynamic nav web service
I am trying to connect to Dynamic nav via web service using a C# client. I added the url in a web reference.
public static List<Customer_Card.Customer_Card> GetCustomersList()
Customer_Card.Customer_Card[] Customers = new Customer_Card.Customer_Card[] { }
Customer_Card_Service service = new Customer_Card_Service();
service.Credentials= new System.Net.NetworkCredential("xxxxxx, “xxxxxx”);
Customer_Card_Filter CustomerFilter = new Customer_Card_Filter();
Customers = service.ReadMultiple(new Customer_Card_Filter[] { }, “”, 1000);
I am getting the following error :
The request failed with HTTP status 401: Unauthorized.
any help will be appreciated
do you run the c# app on the same server than the nav service (localhost) ?
check firewall settings, switch firewall off, try again.
check credentials (user, pw), if this user is a valid nav user. also try with a different user.
use constructor networkcredential(name, password, domain) instead.
try to use defaultcredentials instead.
no its nit in the same server. However I tried the constructor networkcredential(name, password, domain) and the default credentials too , same issue
