Hi everybody Every time I try to make a new mail from the customer or vendor card, using the buttom with the envelope, I get the following error and Finacials stops: “Internal error 3 in module 9” My configuration: database: 1.30A runtime: 2.50 Thanks in advance Preben
This means that a variable couldn’t be created in the proper way, probably because of a wrong definition of the OCX called for the MAPI session. Check if the codeunit called (397) is up-to-date, as you mention a rather old version of the database. John
Thanks for the answer. I solved the problem by taking codeunit 397 from a 2.60 database and imported it to my 1.30 base
