Error 207 in module 160
Any ideas on what this could be? It’s not on fabian’s list of errors. It comes up on launch of the client and ends the session. Uninstall/reinstall doesn’t fix the problem.
This error origins from the Windows Installation. And says there is an error in the RSA encryption. The cause for this is that installation of some program has corrupted a checksum in between the system registry and the RSABASE.DLL file. Try and re-register your RSABASE.DLL to fix this (regsvr32 RSABASE.DLL). If this won’t work, let me know and i will guide you through changing the registry manually. /Soren
