Hello, after installing Navision V2.60.A in past month we have following problems: -there are couple of errors from subject in application log and after that Navision server service stops responding. -manual restarting of service isn’t possible but after such attempt there are “error 11038 in module 244” in log. -restarting of server isn’t possible, we can only do hard-reset Previous version 2.01 on same server works fine. any suggestions ? ------------------------------- moved from “NF Technical Forum” Edited by - rmotzer on 2001 Apr 25 20:37:36
Try 2.60B? It does exist, but I guess it depends on the localisation of the version you are using as to whether its available yet. Craig Bradney Project Manager - Technical Navision Solutions & Services Deloitte Growth Solutions Deloitte Touche Tohmatsu P:+61-2-9322-7796 F:+61-2-9322-7502 E:craig_bradney@deloitte.com.au
