Navision financials version 2.00a. While running the database test (maximum) and while making a backup a message appears ‘error 1200 in modul 19’. The message also displays a damage in the database. Does anybody know what I can do or what the problem is?
Hi Thijs, one of your tables (or more?) seems to be not consistent. First you have to find out the table, when the error message appears. After this, open your database locally and create a new primary key for this table and deactivate the original one. After the keys have been set up, open your table again, delete the new primary key, activate the original one and save your table again. Look into your event log, if Navision service has created an error message before.
