Error 1190 in module 19 during backup. I need help
hi ! i need help . Want to make a backup ( from NA-Client 3.10A )and get an error: Error 1190 … Module 190… Table: G/L Entry… I saw some commets about this problem but no solution. Try and error in this case is not possible because of the size of the table. Does anybody has an idea to solve the problem ? Thank You.
Hello, alexx I had the same problem. Your error message means that you should have an incorrect alpha type somewhere in you G/L Entry table. Did you check the language before back-up and restore? It’s better if they are the same. You should also optimize you database from the tool menu. (if possible). Vanina
