Equipment Management does not exists
I installed DYS-EAM 6.39.600 for AX 2012 R3 CU9 Build 4406, followed the installation guide and the installation is successful, however, there is no Equipment Management under Maintenace Module. Is the patch I installed is the correct one?
That looks like an MDIS - do you have the Partner Feature set installed and the license correctly activated?
Yes, I imported the ALF certificate.
Could you show a screen shot of the license feature sets? Is this the Ti product of EAM, so it states “Dynaway enterprise asset management” and it is enabled with a key?
The license configuration has Enterprise Asset Management enabled and the sub-levels?
I am not sure why you want to see a “Maintenance Module” - EAM has its own menu?
