Hi Friends,
I am facing the error while deploying EP.
"Microsoft Dynamics AX could not locate the Web server. Verify that Enterprise Portal is installed on
the Web server. If Enterprise Portal is installed, verify that the server is available on the network".
Please Suggest the Soloution.
Thanks and Regards,
Muthusamy.V
Make sure that the website you are trying to install EP is on Started state and no other website using the same port number. Once run the Sharepoint configuration wizard and complete through 10 tasks.
HI,
Re-install EP it solve the issue.
Raman Kutala
The issue was the deployment timing out.
Add the following to the web.config file of the EP Deployment Service
<system.web>
</system.web>
The default location for the deployment service on the AOS machine is
“C:\Program Files\Microsoft Dynamics AX\60\Setup\EPDeploymentService\web.config”
