Enum attribute in a query
Hello,
I think I have a problem with a query.
With this code :
protected QueryBuildDataSource addNotExistsSupermarketJoin(Query _query)
    QueryBuildDataSource    qbdsInventDim;
    QueryBuildDataSource    qbdsWMSLocation;
    boolean test = false;
    if (_query)
        qbdsInventDim = _query.dataSourceTable(tableNum(InventDim));
        if (qbdsInventDim)
            qbdsWMSLocation = qbdsInventDim.addDataSource(tableNum(WMSLocation));
            qbdsWMSLocation.joinMode(JoinMode::NoExistsJoin);
            qbdsWMSLocation.relations(true);
            qbdsWMSLocation.addRange(fieldNum(WMSLocation,LocationType)).value(
        strFmt('((%1.%2 == "%4") || (%1.%3 == "%5"))',
        qbdsWMSLocation.name(),
        fieldStr(WMSLocation,LocationType),
        fieldStr(WMSLocation,SPLBlockedPickingOrder),
        queryValue(WMSLocationType::KanbanSupermarket),
        queryValue(NoYes::Yes)
I get this :
SELECT WITH SELECT_ORDER SUM(AvailPhysical), SUM(AvailOrdered), SUM(OnOrder)
FROM InventSum(InventSum_1)
GROUP BY InventSum.ItemId ASC, InventSum.LastUpdDatePhysical ASC WHERE ((ClosedQty = 0)) AND ((Closed = 0)) AND ((ItemId = N'A01090')) AND ((NOT (AvailPhysical = 0)))
JOIN * FROM InventDim(InventDim_1)
GROUP BY InventDim.InventSiteId ASC, InventDim.InventLocationId ASC, InventDim.wMSLocationId ASC ON InventSum.InventDimId = InventDim.inventDimId AND ((configId = '')) AND ((InventSizeId = '')) AND ((InventColorId = '')) AND ((InventStyleId = '')) AND ((InventSiteId = N'DS')) AND ((InventLocationId = N'GHL'))
NOTEXISTS JOIN * FROM InventSumDelta(InventSumDelta_1)
WHERE InventDim.inventDimId = InventSumDelta.InventDimId AND ((TTSId = 5676190081)) AND ((IsAggregated = 1)) AND ((AggregationCounter = 1)) AND ((ItemId = N'A01090'))
NOTEXISTS JOIN * FROM WMSLocation(WMSLocation_1)
WHERE InventDim.InventLocationId = WMSLocation.inventLocationId AND InventDim.wMSLocationId = WMSLocation.wMSLocationId AND ((((WMSLocation_1.LocationType == "Supermarché kanban") || (WMSLocation_1.SPLBlockedPickingOrder == "Oui"))))
where LocationType and SPLBlockedPickingOrder are enum value. Is there a problem in my code ?
Thank you in advance
