Hi all, is there anywhere a list and/or description of all these warnings in the NT Event log file regarding Navision Financials ? I don’t want to call my NSC every time I see a new “unknown” message like “Error 2 in Module 1 Server.C(731)” which is just happend. Kind regards Volker Loepenhaus
This came from Navision: If a Navision Financials client get an error message from module 1 you can from a command line, use a command such as this one (2 is the error no.) : C:> net helpmsg 2 The above command will return an explanation of error 2 in module 1. All errors in Navision Financials module 1 relate to the operating system. Hope it helps
Not in Windows 98 -jp
In Win95/98 you would use: c:>net help 2 /Soren
Hi all, thanks for the answers… But… does somebody of you understand what these errors mean ? Regards Volker
