Enterprise to Standard
What effect will it have if we are planning to shift from MSSQL 2005 Enterprise x64 bit to MSSQL 2005 Standard x64 bit version.
I want to know pros & cons of doing this exercise.
Our DB size is around 300 GB - 400 GB & we run Navision 4.0 with SP3 with around 20 concurrent users.
How will it impact Navision connectivity & performance? Can I do this safely… I mean by backup & restore.
Also I run a transactional replication from my master server which is a enterprise version
to the regional servers which we planning to move to standard version.
Your valuable expertise would be appreciated.
Thanx & Best Regards,
Prashant
Hi!
Well, you should compare the features of both editions: http://www.microsoft.com/sqlserver/2005/en/us/compare-features.aspx
Of course there is a difference between STD and EE, so it depends on which features you need. According to performance EE has some advantages (e.g. ONLINE indexing) but this is not mandatory to run a NAV system.
The backup/restore should be possible - it’s still a SQL Server 2005 -, and IMO even a simple detach/attach should work; just test (I personally use a STD and frequently run customer dbs from an EE without any problems). Also the replication features should be the same on both editions.
Best regards,
Jörg
Hi Jorg,
As sugested I went through the MS link and got confused over one thing perhaps u could throw some light over it.
Under High Availability I found this check in EE but is not there for STD…
Fast Recovery
Available
Database available when undo operations begin
What does this mean…
Best Regards,
Prashant
uhhh … honestly, I have no idea … [:$]
