Hi;
i am using ax 09.i have installed role centers & Enterprise portal.
my installation was successful with no warning & no error. but when i log on to axapta & view for register website form there is no website. for installing it i have properly created website in IIS &
also mention the website name at the time of Installing role centers & Enterprise portal .when i login to ax at home page nothing is getting displayed for rolecenters . i have attched userprofile with user. help is needed for the mentioned issue.
Hi Neeraj,
How did you install EP and role center? If you haven’t done so, please refer to the documentation and make sure you have followed steps correctly. Here are some links -
Enterprise portal administration guide
[Tips and tricks for implementing enterprise portal & role center](https://mbs.microsoft.com/partnersource/documentation/howtoarticles/ax2009_epinstall.htm?printpage=false&stext=Enterprise portal Ax 2009) [Requires PartnerSource login]
