Dear Friends,
when i installing the Enterprise Portal getting the error uninstall the manifest first tried every thing to solve the issue which got through googling for this error. . following things are done in AX installation.
Restored the contoso DB and updated the user info table.
installed the AOS and changed the BC account.
installed the reporting server extension and deployed the reports.
tried to install the EP and got the above error.
Even i tried to install the EP in differnet server which BC is pointing to this server but getting the same error.
2015-09-29 22:21:09Z Entering method deployEPOnSharepoint
2015-09-29 22:21:09Z Deploying Static files…
2015-09-29 22:21:09Z Wrong argument type for function. - (C)\Classes\BinData\setData
2015-09-29 22:21:09Z (C)\Classes\SysResource\exportResource - line 37
2015-09-29 22:21:09Z (C)\Classes\SysEPDeployment\deployImageOnServer - line 40
2015-09-29 22:21:09Z (C)\Classes\SysEPDeployment\deployImagesOnServer - line 56
2015-09-29 22:21:09Z (C)\Classes\SysEPDeployment\deployStaticFilesOnServer - line 51
2015-09-29 22:21:09Z (C)\Classes\SysEPDeployment\deployEPOnSharepoint - line 19
2015-09-29 22:21:09Z (C)\Classes\SysEPDeployment\installEnterprisePortal - line 21
2015-09-29 22:21:09Z Microsoft.Dynamics.Framework.BusinessConnector.Session.Exceptions.XppSessionException
2015-09-29 22:21:09Z at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsSession.HandleException(String message, Exception exception, HandleExceptionCallback callback)
2015-09-29 22:21:09Z at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsObjectAdapter.Call(String methodName, Object param1, Object param2)
2015-09-29 22:21:09Z at Microsoft.Dynamics.Framework.BusinessConnector.Proxy.SysEPDeployment.installEnterprisePortal(String virtualServerUrl, Boolean developerInstall)
2015-09-29 22:21:09Z at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.DeployEnterprisePortal(String virtualServerUrl, Boolean developerInstall)
2015-09-29 22:21:09Z Microsoft.Dynamics.AX.ManagedInterop.ErrorException
2015-09-29 22:21:09Z at Microsoft.Dynamics.AX.ManagedInterop.Object.CallWithReturnType(String methodName, Type returnType, Object[] paramList)
2015-09-29 22:21:09Z An error occurred during setup of Enterprise Portal (EP).
2015-09-29 22:21:09Z Reason: Setup encountered an error during deployment of the Role Center and Enterprise Portal framework.
2015-09-29 22:21:09Z Registering tracing manifest file “C:\Program Files\Microsoft Dynamics AX\60\Server\Common\TraceProviderCrimson.man”.
2015-09-29 22:21:09Z WEvtUtil.exe install-manifest “C:\Users\cemadmin\AppData\Local\Temp\2\tmp38CE.tmp”
2015-09-29 22:21:12Z **** Warning: Publisher {8e410b1f-eb34-4417-be16-478a22c98916} is installed on
2015-09-29 22:21:12Z the system. Only new values would be added. If you want to update previous
2015-09-29 22:21:12Z settings, uninstall the manifest first.
2015-09-29 22:21:12Z Tracing manifest file has been registered successfully.
2015-09-29 22:21:12Z === Rolling back setup of Enterprise Portal (EP) due to error ===
2015-09-29 22:21:12Z Running Msiexec.exe with these parms: /i “\common\Softwares\AX2012_R3_CU8_setup\MSI\Components64\Components64.msi” /qb! /l*v “C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2015-09-29 22-13-56\Components64 Rollback Log.txt” DIRECTEXECUTE=1 /norestart INSTALLDIR=“C:\Program Files\Microsoft Dynamics AX\60” INSTALLDIR32=“C:\Program Files (x86)\Microsoft Dynamics AX\60” ADDLOCAL=“EnterprisePortal,NetBusinessConnector,ModelManagement,ClientConfig” REMOVE=“EnterprisePortal”
2015-09-29 22:21:12Z Running synchronously.
