Ma getting the error when loading the ssrs port in enterprise portal if it loading less pages its coming fine but some case the report contain more pages that time it showing some error…
Below Error message reference
"Microsoft Dynamic AX Enterprise portal :The Request Timeout .Please try to resubmit the request …
Thanks in advance .
I had the same issue and solved it by altering the page_load method in the code behind of the particular webcontrol: protected void Page_Load(object sender, EventArgs e) { ScriptManager scripts = ScriptManager.GetCurrent(this.Page); if (scripts != null) { scripts.AsyncPostBackTimeout = 600; } } This will set the Ajax postback timeout to 600 seconds instead of 90.
Tilak.
