Hi Expert
i found the below statement at dynamicsuser.net/…/19622.aspx
As many know, NAV uses an application role to enforce security for regular (non-dbo) users of it’s SQL databases. The primary difference between Standard and Enhanced is that for the Standard model a single application role is used and all users access tables using this role, and for the Enhanced model separate application roles are used for and owned by each user.
may i know where to find the above feature( in bold and underlined), appreciate if you could give screen shots. thanks
