we have a server in this ax practice,axtv and Dynamics ax1 are the instances with the port numbers are 2714,2713 and 2712.once i restart the server system the service 2712 is unable to start the remaining two are started.i get this error
windows could not start Dynamics ax object server 5.0 Dynamics ax1servive on Local computer
As with learning other areas in AX, there is no shortcut in learning AX Administration. To start with if you haven’t already done so, start studying DAX 2009 Server and DB administration guide which can be downloaded from here - http://www.microsoft.com/download/en/details.aspx?id=21551
Other than the above, there are loads of materials in standard help documents such as system and application setup which comes part of DAX 2009 client installation.
