I want know how we can enable filter in any form which is already disable filter
for example i just attached a screen shot with this mail given below
There is a invoice journal form as you can see in that form there is a field AccountName so i just want to enable filter on that
field same as it has for Journal Number Field.
AX Version 2009.
Thanks in Advance
Hi ,
Can you tell us the path…(Like AR->Journalls…)
Looks like they are customized fields (usually they will be on lines) and they look like the display methods. So filtering is not possible on display method without a change.
Path AP->Journal->InvoiceJournal
thanks your quick response.
you mention that not possible without change. what does it means
Filter is only possible on the data base fields. But it wont be possible on display methods without doing a customization.
Is the form customized ??..Tell me from which table the name field comes
Thanks for your response. i will try above link
this is the display method and coming from LedgerJournalTrans Table see given code
//BP Deviation Documented
display LedgerJournalAccountName accountName()
LedgerJournalTrans ledgerJournalTrans;
select ledgerJournalTrans
where ledgerJournalTrans.JournalNum == this.JournalNum;
return ledgerJournalTrans.accountName();
Thanks a lot it is working fine.
HI,
Always Close the thread if you got the answer by clicking ’ this helped me’ in the useful reply…
A journal can have multiple lines with multiple accounts. Which one will you show on the header with this display method?
HI,
As per ur reply i will consider my reply as answer…
