Change the AutoDataGroup of the Dimension group in the form to NO. Change the names of the dimensions in the group and set the autodeclaration property to yes.
In the active method of the form data source and in the modified method of the offsetDimension field change the enable \ disable logic by using the above auto declared fields…
