Hi folks,
I have setup document approval in dynamics nav 2013 and everythings
seems ok so far. But the problem is that when I do an approval request
the person who is supposed to approve the request receives a mail with
empty information.
I am still trying to figure out what exactly is the problem. Please I need advice
on this.
spaul
March 11, 2015, 2:42am
#2
I believe there is code unit 400 which is NAV’s SMTP that you can utilize for this type of email. The coding is minimal and you should be able to search for it here.
Good luck.
You need to import an e-mail template: if it’s empty you can start from the one in the Cronus company and modify it based on your requirements.
Where in the nav system do I import it from from.
Application Setup > Document Approval > Approval Setup > Navigate > “Approval Mail Template”
