Employee name and Id in dropdown ????
I want to get both the employee name and id in the drop dowm.
how can i get it?
-Rajee
These two fields are coming from the same table (or) diff tables ?
Employee id from EmplTable
Employee name from DirPartyTable
Set the EmplId EDT to your field
This EDT will lookup the Employee Id & Name
In default EmplId EDT is set but the lookup shows only the EmplId,but not the name
Override the lookup method…
Both are taken from two different tables, how can i address this in the LOOKUP method? Employee id from EmplTable Employee name from DirPartyTable
In the lookup method,i wrote this ----- EmplTable::lookupEmplId(_formControl); ----- and got the lookup with both name and Id :slight_smile:
Thats fine[:)]
