I need to add some embedded code on my reporting services report for a SalesPackingSlip in Ax 2012 but when I add my custom Visual Basic code to the report and I close the report designed and I open it again my code is no more there so I can not use it on the expressions.
Any idea?
Where did you write the code? In a data method?
Hi!
Just in the report. Something like this:
Add Code to a Report (SSRS) (section embedded code)
http://msdn.microsoft.com/en-us/library/ms156028.aspx
It doesn’t work for me either. I don’t remember any information about this feature related to AX, but it looks like it’s either not supported or broken.
I would recommend to use a data method, that works without problems.
