Eliminating Table Filter Tab on Report
I’m creating a report using the following tables: DataItem Name Customer _Cust. Ledger Entry <Cust. Ledger Entry> Integer Integer When I run the report I have filter tabs for tables: Customer (that’s okay), Integer (not okay), Integer (again, not okay). What causes these to show up and not show up (notice I’m not getting one for Cust. Ledger Entry), and how can I eliminate the tabs for the Integer table instances? I have no filter fields listed on the properties for the Integer tables. All help appreciated.[:)]
[:o)]Uh…maybe I should have completed the coding first![:o)] When I told it to sort on number on the integer tables, the tabs went away. So, now we know! Lesson learned * 2.[:I]
