I have an EDT as an Array of 3 elemetns, which is saved in a table as three fields. I have to display the value of all three fileds in a report if they are not empty. How can i get the value of these fields in code by writing a display method.
thanks
Hey,
This is really good question “I Like it”.
Actually Dimension is a good example for your case,
first of all you should as what microsoft do with Dimension
1- Define extended data type as Array it self with two internal Arrays,
so we end up with three Arrays.
just look to the Dimension extended data type it is a live example.
2- this is the answer to your question
you can diplay it one by one.
Example to display Department (Dimension 1)
display sysdim Dimension1()
return CustTrans_1.Dimension[1];
Thats it
Appreciate your answer brother. I have tried and its working now.
thankyou
