edit field error
i am trying to edit some fields in a table and get this error message:
" Error Message (11:03:14) Cannot edit a record in …The values displayed in the form are not current, so an update or deletion cannot be made. To view the current values, on the Command menu, click Restore. "
does anybody know what this means ? TIA
That means that there has been an update to the AX table (i.e. the database) but the form you are using has not been refreshed with the up to date current values thereofre you need to select command >>> restore to update the form with the most up to date values.
Usually this happens when the developer of the form made an update to the database but forgot to call the reRead() and refresh() methods or executeQuery() method on the datasource to get the form up to date so it can be called a bug in the form you are using.
Hope this helps
Thank you very much MirkoDAX.
