Edit button is enabled even the safety level of invoiced orders is set to Locked
When the sales invoice is fully invoiced edit button should be grey out. I have set up the below properties but it is not working.
Account receivable parameters → updates → safety level of invoiced orders is LOCKED.
Are there any changes should be done in coding?
Please suggest
Thanks ,
Lakshmikanthan K
This will not let you update or delete an invoiced order.
Is this not happening in your case?
Thanks for the reply Kranthi,
Yes.
I have set up the same property in another environment where it is working.
I don’t know how to fix this, anything I have to check in coding?
If it working in one environment and not working in another environment, then it could be a code issue.
Try debugging,
\Classes\SalesTableType\checkUpdate
\Data Dictionary\Tables\SalesTable\Methods\checkUpdate
