Hi All
I had create dispaly Method in form But My end uer Not editble That field
So My End uer Want Edit field which Method I have to create plz help any one
Thank you
Hi All
Thank you
What is the code u have wriiten?
Check in the field property or in any method, they might have written with allowedit(false).
Hi ,
I had write code in table method
look_in table
Display Name Brand ()
Name ret ;
ret= look_iin::find(this.id).brand;
retrun ret;
The display method is used to just display the values it shouldn’t be editable. If u want editable field use edit method instead of display method.
Thank you jyothi
if u dnt mind give me any example code
