Can any one pls explain the actual purpose of edit and display method?
Thanks & Regards
Manjusha.D
Thanks & Regards
Manjusha.D
Display method–genrally used in forms& reports-for view purpose!!
i,e it just display the value to end user and it doesnot store any values in db.
edit??- i dint get that…
regards
Shon
Edit method is also like the display method - but you can write some values into it.
For reference see the InventQuarantineOrder form - showComplete method.
when you select this - it will show the ended quarantine orders. Otherwise the non ended orders…
thanks kranthi
Hi
Thx for the reply
Can u pls tel the actual purpose of writing edit methods. For example edit noyes base methods in axapta
Edit Methods are EDITABLE display methods.
Check out AP> Vendor > Functions>Open Transaction Editing form . There “Amount to Settle” field is a editable display method.
Check this : http://msdn.microsoft.com/en-us/library/aa637541.aspx
Snip from Developers help -
An edit method is a variant of a display method. It returns a value to be displayed on a form and accepts user input.
In addition to the above definition, there are guide lines published in Developers help such as where should display/edit methods should be written, why writing these methods on form is not a good idea etc. You may want to take a look.
HI kranthi,
Plz tell me how to save edited values …In CalculatedControl(Edit method) in form
