I installed E-ship and EDI. I was confusing with EDI. May I know by default is EDI Documents, segments, segment elements come are not. How to Installing/upgrade Edi Documents, segments, segment elements.
Usually whomever you want to do EDI with has a template that they provide youto help you build your documents.,
Check out Trading Partner->Documents
there you can setup & build them as well as adding segments & elements.
Did you also setup the Help files?
Here’s an old mapping guide it will help
https://docs.google.com/file/d/0BwY098pPvpANdGE5ZkhmaEVfXzg/edit?usp=sharing
